Have a 2014 6x6 Big Boss and really want a front tow bar, so I can easily reverse my boat trailer to the sea (have several curves down to the water, and no possibility to turn around)
Haven't found original parts, but I am sure somebody have done this ;-)
But how?
Have a 2500 lbs winch installed, and need to keep it (would believe that the mounting points to this will be strong enough) but as mentioned, I need this also....
Any tips, hints etc....?
Sent from my SM-G955F using Tapatalk
However you do this you do not want the trailer tongue to be putting its weight on the ball. The front and even a rear ball cannot take that kind of weight.
I know, have made a supporting wheel in the front of the trailer. So there will be no load, except forward or aft...
But good point !
