1 - 12 of 12 Posts
Anyone have a bearing part number other than going to the dealer for one.
Front hub bearing for 04 Sportsman.
Yes thats the Polaris part #. I was looking for a cross reference # to an aftermarket bearing like NTN, SKF,FAG,etc. I got it of a forum a long time ago for the rear bearings and i think the front were on there to but i can't find it or i threw it out.
Sp700 Rear wheel bearings Federal-Mogul Bearings 510013
Sp700 Front wheel bearings BCA 510014
Sp700 Rear drive shaft U-joints NAPA # 338
?? Thermal sensor - tells fan when to come on - Wells SW526 less than $30
Sp400 & 500 Oil Filter STP SMO17
Sp?? Fan www.offroadwarehouse.com
Sp500 Fan p/n 30100515 800-341-7757
Sp600 or sp700 oil filter Super Tech ST7317 at Wal-Mart
Need a front dif rebuild, these parts worked on my 04.5 700.
2 Federal Mogul 108 (output bearing)
2 CR# 15801 (output seals)
1 Federal Mogul 306 (input bearing)
1 Federal Mogul 9748 (input seal)
1 CR Speedi-Sleeve 99098 (for input shaft seal)
1 NTA 815 (needle bearing)
NAPA U-joint(338) works on the inner joint of front stock c.v. axle. (SP700)
Stock CV boot for '02 700: Discount Auto Parts P/N 6-1052 Fits Dodge Neon, not sure what year. (front outer match)
Stock CV boot for '03 sp700 Car Quest part # 85-0904 (front outer match) NAPCO.
This is the parts I just used in order to rebuild a rear end on a 2003 Sportsman 600.
Jew your parts dealers for the best prices. I rebuilt this one for less than $90.
Beware that if your Pinion and Ring gear is bad the best deal I found is $250.00 from Polaris. (Just in case)
2) Bearings - 6010-2RSC3 SRI-2 The brand is KYK
1) Bearing - 6306-2RSC3 SRI-2 The brand is KYK
2) Seals - Polaris PN 3233878
1) Seal - Polaris PN 3233785
1) Bushing - Polaris PN 3233577
1) Qt 90w Gear Oil
These are just some other parts that may help you.
U-joint for 2002 700 sp rear prop shaft # 1-0170 this is a SFK brand
U-joint for 05 700 sp rear prop shaft - 338 this is a Precision brand may be the same a 02 model??
Rear axle bearings for nearly all Sportsman's that I'm aware of # 510013 this is a Federal-Mogul Bearing
CV Boot kit for the front of '05 model Sportsman's # 8409 this is a Precision brand.
CV Boot kit for the rear of all 600-800 model Sportsman's that I'm aware of # 7427 this is a Precision brand (rear match) cross to NAPA # 686-2151 ($12).
THE FACTORY POLARIS FAN FROM A 2004 POLARIS SPORTSMAN 400 AND YOU CAN GET IT FROM POLARIS FOR 200 (U.S CURRENCY) OR YOU CAN ORDER IT FROM THE COMPANY THAT MAKES IT FOR 72.00 PLUS SHIPPING. THIS IS THE EXACT FAN. THE PART NUMBER IS SPAL VA07-AP12/C-58A Fan (30100452).HERE IS THE NUMBER TO ORDER IT 800-345-0327, AND THEY MAY HAVE THE OTHER SPORTSMAN FANS ALSO. ENJOY. ""
More stuff, SP500 with the hubs that lock. Front wheel bearings that go inside hub & strut. Timken L44649 & L44643 can be bought at Napa or any parts store. I measured the oil seals and call a local bearing supply store. They wanted more for the seals than Polaris did.
Just thought I would add the Napa Rear wheel bearings part #'s for Trail Boss 330 are PBR17 These are the tapped bearing still had to get seals from dealer
1) Qt 90w Gear Oil
__
1995 Polaris Magnum 425 2x4 front wheel bearings are part # 6204 or 6204LLBC3/L627 on grainger
also the wheel seal is 34823 standard 2k axle wheel bearing.
1 - 12 of 12 Posts
