I have a 98 Magnum 425 on which the rear drive chain just recently broke. In order to get home, I selected the 4wd mode and drove in with just the front wheels powered. It steered with some difficulty, but I made it. Today I went out to work on it and it would not move forward, only reverse. The CV shafts are moving, but not the ATV. Putting it in reverse and pressing the override button allows travel backwards. Any suggestions?
It also seems as though the clutch mechanism has started to wear through the plasic cover, exposing the internal parts. The cover is on and in the correct position. It makes quite a bit of noise at idle but as it starts to engage the belt, it stops and compresses enough to miss the cover.
I am new to this sight and appreciate the fact that so many people are willing to help.
