1 - 16 of 16 Posts
I have a 2007 Sportsman 500 6x6 and both front wheels do not engage in 6x6 mode. The light comes on the pod when switched but wheels do not turn.
I'm changing the hub fluid this weekend hoping that it could be just that.
How does the front hubs engage, mechanical or electrically ?
What are the steps in troubleshooting the issue.
Try changing fluid first. They engage electrically thats why you need clean fluid in order to operate correctly. It could also be that you have a brocken roller cage inside the differential.
It don't have a cage in the front diff. Hilliards are in the hubs. Change fluid first and check connections to the struts.
Are you actually jacking the machine off the ground to check it? It won't engage till the rears slip.
They didn't go to a central Hilliard in 2004.5 like ATVs?
Sean
Discussion Starter · #7 ·
thanks, i will change the fluid first. I noticed that the front was not engaging while going up hill in reverse and that the back tires were slipping and the front was doing nothing.
For the AWD to work i reverse you need to press the yellow overide button on the handle bar.
Reactions: Rob06polaris
:withstupid: What he said.... AWD in Reverse = Press & Hold Yellow Override button (left thumb), while AWD switch is engaged!!
It also won't hurt to change the hub fluid!!
I really wish I knew this too weeks ago..... Can't wait to test it this weekend.
thanks for sharing this!
do NOT hammer in reverse with that button pushed. Or at least that’s what I’ve been told.
Understood... and agree...but still very interested to see if this has been my issue with traction will backing up in reverse with a trailer , thanks again for the tip
They won't pull the hat off your head in reverse if 4x4 isn't engaged and 4x4 isn't engaged in reverse unless you're pressing the reverse override button.
There is a thing called an owners manual that is just chocked full of useful information - maybe you should read it and get a better understanding of your toy.
Yep, and they're free for download on Polaris' website.
1 - 16 of 16 Posts
