2012 550 xp eps.
front prop shaft: u joints are shot, so I knocked out the pin in the front yolk but the yolk is frozen on the splines. the back of the prop shaft rides easy on the trany side as I can see from all the play in the ujoints. whats the trick to get the yolk off without destroying the front differential? I will try more spray and more time but I hope someone has a trick.
thanks
thanks
