1 - 2 of 2 Posts
I have a 2017 Polaris Sportsman 450 H.O. It is pretty much brand new with only 40 hours on it. For some reason fuel is not getting into the engine. If I put fuel in the engine it will start for a few seconds and then cut out. I think it has something to do with the wiring connection to the fuel injector because when the wires are in the plastic connector it won't start, but if I do a direct connection to the fuel injector without the plastic connector it starts right away. Has anybody had these same problems? Anyway you can fix this without having to order a whole new wire harness? I am getting the error code 0-651-5.
1 - 2 of 2 Posts
