I have a 98 scrambler 500 that used to run great. Then only ran on choke. Then not at all. Overhauled the entire carb. Fuel lines. Petcock. Fuel pump. Even got a new carb. Still having issues getting to run. It's spitting gas into the filter but not filling it up to keep running. Please help!
Font Window Pattern Screenshot Automotive exterior
to the forum
Gas Font Automotive lighting Ball Vehicle registration plate
Administrator
Fuel filter does not need to be full - fuel will flow through the filter past any air trapped in the filter - the problem is probably the carb.
Discussion Starter · #4 ·
Yea. Even a new carb and still nothing. I did finally get it to idle but when attempt to throttle it dies. I sprayed around intake with parts cleaner and idle fluctuates. Has some small cracking but doesn't appear to be leaking but ordered new one to test. Just stumped because this is something stupid simple and it's kicking my ass.
04 Sportsman 700, 04 Scrambler 500, 04 trail touring 550 sled
If the idle fluctuates, then it’s clearly leaking. Although the intake boot is the problem, you can give the etc switch above the throttle lever a check, should be about an 1/8” of play from when the lever is pressed until it actually starts pulling the cable.
