I have a '05 Polaris sportsman 500 H.O. it has been sitting a few years and. I have cleaned up the carb and it will run and stay running till the fuel in the filter runs out. I can keep fuel in the filter by pressurizing the take to push it through but will soon run out. what could the problem be?
Discussion Starter #3 (Edited)
I installed a new filter and double checked the flow direction and is installed correctly. I have pulled the pump line from the carb on the drivers side to the pump and that hose seems to be pumping air through it when engine is running any other sugestions? there is gas in the pump
