I know there are a lot of threads in this, but I have a 2016 SP and it looks like it has a flexible heat shield on the bottom of the tank from the factory. One of the threads has a link to a shield that claims to come on the 2017 and newer to protect the fuel pump from heat. Is this one metal or is the same flexible heat shield tape that is on the 2016? Going to order it, but wanted to make sure it was something different. Going on my third fuel pump and got to stop this. First replacement was OEM under warranty. Going with quantum for the next one.
yes the newer models have metal heat shields. its a kit that can be added to any 570.
Post #2 has the part numbers you'll need
Reactions: Sprotsman
