I have a 2007 Hawkeye, it has a carb. My question is should fuel run through it when motor is off? My son was riding and it quit running, pulled into shop and fuel was pouring out the bottom of carb, shut fuel off it quit. pulled line going from outlet of fuel pump to carb, turned fuel valve back on, and fuel ran out of line. My question is with engine off should fuel be going through fuel pump? My other thought is, if fuel should be going through, is the float stuck causing fuel to run all over. Any input?
