Welcome to the forums!
Could be caused by a loose fitting, corroded or overheated terminal from the original pump failure. Check all of your electrical connectors for good clean and tight terminal tension. Check all grounds for being clean and tight. Try wiggling connectors and wiring to and near the pump to see if it changes anything.
