1 - 8 of 8 Posts
Anyone have a schematic or a diagram on how the fuel pump is hooked up on an '03 Scrambler 500?
If your going to use a electric pump make sure it is regulated at 1-3 psi to much pressure and the needle ansd seat in the carb won't be able to hold back the fuel and flooding will happen or the fuel will run out the over flow tube on the carb.
Discussion Starter · #7 ·
Very true Mickey. I have a "Mr. Gasket" electric fuel pump on my John Deere. It averages around 1.5-2. Works very well!
1 - 8 of 8 Posts
