1 - 12 of 12 Posts
I have spent hours searching for videos and I've searched these forums with no luck. I'm trying to find a video on the fuel tank removal. I just don't want to start taking things off that I don't have to. Plastics are off. 2 bolt mounts at the top. detached all wires and lines. Should I be able to wrestle it out without taking other parts off?
I took a tree limb that broke off the right front drive shaft and put a 2" hole through the gas tank. Any guidance is much appreciated. Thank you!
Sounds like you have the hard stuff off. Might have to pull the air box. It should be straight forward.
Manual 9924865 - PM me your email address and I'll send you a PDF copy
Is there any way I could get a copy of that PDF manual as well. I'm working on my 550 x2 and needing to troubleshoot some fuel issues and this would be helpful. Possibly needing to remove gas tank along with some other things.
I really could use a copy to please
Reactions: lou811
1 - 12 of 12 Posts
