1 - 1 of 1 Posts
Hi i have a 2009 Polaris Sportsman 400HO. Every time i go to start it it wont start. i hook up a volt meter and it says there is a draw of 4 Volts even when the key and the kill switch are in the off position. I was wondering if there is a fuse box and where it is so i can pull fuses until the draw goes down to around 0 volts then troubleshoot from there. Thank you very much.
1 - 1 of 1 Posts
