I have about 17 hours on the unit. Have noticed that when running in sand for a while, engine under load, I started smelling gas. Today I took my pyrometer and when i shut it down after a few miles in the sand. The side of the gas tank that faces the engine was 160 degrees and vapors were poring out of the vent tube. I could here a sizzling sound. I assume that was gas boiling on that side of tank.
The engine is not overheating, fan cycles on and off as normal, 194 - 206 degrees. I took temp readings on the belt housing transmission and so forth, all was ok.
Anyone seen this before? what was the answer?
I have read about this and finally experienced it not too long ago.
I was plowing for several hours and heard the sound after I was done & shut the atv off.
Took off gas cap and actually seen the gas bubbling.
Like I said, I read about this but can't believe a plastic gas tank would
hold up to gas boiling. I think I remember reading gas can start boiling
@ 104 degree's or so, but don't quote me on that.
Boy, this one is a head scratcher. I Wonder if you don't have a plugged vent line from the tank, that would cause pressure in the tank. On my 500, If I take off the gas cap while it is running I hear the same sound but I know for a fact the fuel is not boiling. It is the fuel return. I would say check your vents and cap too. If you have boiling fuel You have a big problem and better see a dealer. Just my opinion.
I havenever heard of this from a Polaris but Grizzlies had a similar problem. I think they had a heat shield issue though, but not for sure.
I am going to throw this out there but have never seen it. Could it be possible that the tank is under a vacuum - as in not venting?
Yes the 07 & 08 Yamaha Grizzlies had the problem. Yami fixed it by replacing the "roll over valve" which is a fancy name for the tank vent. Check your venting system. Be sure it's not kinked or blocked. If there is any kind of one way valve in the vent line you can change it out with a small fuel filter from NAPA. This is what the Grizzly owners did until Yamaha came out with their factory fix.
Well a vacuum problem would certainly fit the description. You say it does it while on heavy load, so therefore you are ingesting much more fuel than normal. If the venting system is not supplying ambient pressure back into the tank then the gas would begin to boil off under vacuum.
2011 Ranger xp 800 excessive heat
Hey everyone. Im new to the forum but have a new 2011 ranger xp le. Sorry to say guys but this is a factory DEFECT. my little girl was scalled sitting in the center of the seat where I now know heat is blasting through. I called Polaris and gave them a piece of my mind. I will NOT buy some after market fix to repair something that is obviously and engineering f##@ UP!.
Also apparently some of the dealers are dialing down the fuel mixture wihich IMOP is treating the system and may damage tghe engine further down the road. No Polaris needs to fix this and needs to hear from all of you as well.
Thanks all
Pman
