Gates new Redline Series Belts
13K views 38 replies 12 participants last post by  taken
#1 · (Edited)
Getting ready to try one of these new Gates Redline belts on the 1k.
They're recommended for the new 1000 S and Scramblers for extreme use conditions.
I've been using Gates standard G Force belts for years with very good results and thought I'd try Gates' latest and greatest offering.
Anybody running one of these?
I'll let you guys know what I think after a few hundred rough miles in the mountains.
#4 ·
Gates user myself, keep us posted.
#10 ·
Not the Redline but the Gates C12 Carbon on my Sportsman XP 1000 and it's a 100% AWESOME. Gates was recomend by the parts guy at my dealer so I got one and glad I did only thing I will say is that it needs a good break in before you start hammering on it or it will slip.
#12 ·
I’m curious about the Redline. I currently have a Gates Carbon but am thinking of upgrading to the Redline if it performs well. I like the idea of being able to run hotter since I know my snorkel system is restricting air flow from factory settings and therefore keeping things hotter in the clutch housing.
Reactions: MrEd
#13 ·
Update on the new Gates Redline belt.
I'm thinking this is gonna now be my go-to belt. Super smooth engagement, good engine braking and ADC response and doesn't seem to heat up as much and get sticky like the regular Gforce belts do after long hard climbs. I assume its due to it being a different rubber compound. I've been very busy lately and haven't had the opportunity to put a real hard ride on it with extended long climbs but I'm very happy with it so far. It'll get that torture test in about a month in the high Rockies lol.
G, I ran a carbon belt on my 800 a few years ago and didn't really like it that much. Seemed like the braking action wasn't as strong as the regular Gforce. I figured it was probably a much harder rubber compound and not as sticky in the clutch sheaves as the regular Gates belts. I'm sure the carbon belts probably wear less and last much longer if that's what you're after though. They are super strong belts, but my sorta seat-of-the-pants feeling when comparing the two is that responsiveness and down hill braking action is not as good with the carbon belts. I run mostly all vertical terrain and like my belts to bite and hold back when I need it. I also change belts often (around 3000 miles or yearly) and I run in high gear most all the time so I wear belts anyway. Having a belt last for many years without changing really isn't a concern for me.
#14 ·
Thanks for the review, I may pick one up.
#16 ·
Hey Poleman500 ,when you installed the redline did you have any issues with jerkiness? I installed the redline a few weeks back but didnt get to move the bike until yesterday and its jerky and the hard shift like the 1way bearing is shot. Thats with a new 1way bearing and the existing RVS clutch kit(thin shim). With that said i only pulled it out of the garage to turn it around so the new belt only has 100ft on it. Is that normal for the gates before the normal break in procedure?
#17 ·
I've forgotten exactly what machine do you have Duse?
Did you check belt to sheave clearance? Needs to be at least .020 clearance between the belt and sheaves.
What number Redline belt did you get?
There's a 3836 for the older models and a 3856 for the newer ones. They have slightly different length and width dimensions.
#21 ·
LOL... Well, clutch tuning and belt brand/type changes are a trial and error sorta thing Duse. After you do it a while you can most times get it right the first time but it takes some T&E to learn to check all the variables/clearances before putting them back together.
You can run it a while to see if the belt wears in and gets better but I'd suspect you may need to swap in the thicker shim. No two belts are the same... different brands and varieties of even the same brand belt requires fine tuning to be just right.
A new belt of any brand or persuasion with a freshly rebuilt and cleaned/scuffed clutch are sometimes a little sticky and needs some break in to be super smooth to shift. A little drag or stickiness when everything is new is not unusual but if it persists after a couple hours running it needs to be adjusted.
#23 · (Edited)
Got off early so I pulled the clutch cover off.The belt is riding tight on the stationary sheave ( inner sheave,sheave closest to motor)
Clearance from the belt to the movable sheave is @.051
With that said am I still looking to add a shim to the drive, or remove a shim from the driven(if there is a shim to remove)
#25 ·
Yes I believe you are reading it right. I probably should have written .,,,The belt is riding tight on the "Drive clutch" stationary sheave .
Im guessing I can just pick up a 1 1/8"(ID) washer from hardware store to put on the shaft or is there a specific OEM washer I should get ?
#26 ·
Sorry Duse... I was thinking of the older style driven clutches like on the 500 when I told you to shim behind the secondary. The newer XP machines shim differently with small flat washers under the retaining bolt. Up to 4 total is recommended. Part number 7556580
But... Here's a link to a thread on a DIY variation using washers from the hardware store
#27 ·
Thats not even a 👍 post. Thats a (y)(y)(y)(y)(y) post.
I already pulled the secondary to get a shim behind it and dreading whatever shim I put there wouldn't be right because its such a PITA getting the driven out.
Makes it soooo much easier to add or remove shims through just the retaining bolt
I had to read this part 3 times to understand how shims on the retaining bolt would pull the secondary out,,,
The whole design of the XP secondary is the free float, it in a sense lines itself up so belt doesn't drag, but without those small shims, the bolts draws the secondary down too far, shoving the belt too far towards the engine"
,,,but now I got it.:giggle:
BIG HELP,Thanks so much👍(y)
#29 ·
Turns out I had 2 shims on the clutch .And there were 4 oem shims on the spare clutch I have.
Added 1 shim ,still had the drag. Added the 4th shim and drag was gone but did not have the .020 clearance on both sides of the belt. Added another shim(Total of 5 and it gave me the .020 clearance. I figure Ill run around for a couple hours and see if the belt centers up some more so i can remove the 5th shim
#30 ·
I'll let ya'll know...
