The ratio between the crankshaft of the engine to the transmission is a constantly variable belt drive - the actual ratio is not published but in therory it is 0 at idle and 1:1 at full throttle and at maximum speed. The 'transfer case', is a transmission and there is a fixed gear reduction with the choice being low range, high range and reverse and I do not know the overall reduction of the gear box to the final drive or what the reduction to the tire surface would be.
The power is typically BHP at the rear wheels the engine probably has appx 15 to 20 crankshaft HP, but that depends on RPM.
