I do routine water crossings with my 2010 sportsman I plan on using it plowing and ice fishing this year are there places water may be trapped and cause issues when it freezes? Are there any other PM's I should do leading into winter?
I make a habit of changing the front diff fluid and trans fluid late fall. Keeps it nice and fresh for winter plowing
Also, grease the machine too, check coolant.
If you are concerned, pull the drain plug from the clutch housing, just to see if it is dry.
Thanks,
Will
2012 Sportsman 400HO.
Diff fluid for sure. Buddy didn't change his before winter and it froze. That was a $500 mistake he won't make again.
