need help please When i push the throttle on my 01 ploaris scrambler it takes a while before it gets up to speed thank you
Sounds like it could use a new belt and the clutches cleaned. You will probably have to adjust the belt deflection for max performance on both bottom and top end. This is easy to do and will make the machine fly.
The clutches are by your left foot inside the big plastic clutch box. If you want to know any more give ma a call at 651-340-1129. This post would be a mile long and explaining the clutching is easier over the phone.
