Well on a brand new plow system with my sportsman one of the skid shoes lasted 3 plows. Broke right at the weld on a pretty good condition asphalt. Would this be covered under warranty?
137063
Not sure what brand it is but I bet they are not covered under warranty, however since they are relatively cheap I would assume that a company with any integrity would send you a new one to keep you happy.
Im assuming you recently bought the plow. From the picture it looks like there was a issue with the weld when you bought it....My guess is the dealer will warranty it.
Sent from my SM-N975U using Tapatalk
Easy fix instead of buying new ones. Likely not under warranty....weld the shoe back on. Get a small plate of 1/4" AR steel and weld it to them.....Any steel place should have it or you can order it online....it will be the last time you ever have an issue.....
