Is it the same for all models?
If I buy a plow for a Sportsman 450 will it also fit an 850? I assume so but want to be sure.
Thanks!
Since you are still shopping I would really look at the Denali plow system. I got a quote from one of the reps that is on this forum. They shipped a complete set up to me for less then half what it was going to cost to pick up a Glacier set up from the dealer. It is a high quality plow and have been using it for three years now with no complaints. They could also tell you what makes and models their plows will fit. I am guessing (could be wrong) that the plows themselves would be the same. You could get a mounting plate for each quad and leave them on and just put the plow on whatever machine you are using. The mounting plate stays on mine year around and then there are just two pins that hold the plow on.
