Hi. I have installed a Glacier III plow system with a 66 inch poly blade on my 2012 polaris sportsman 550 touring , my question is do i need to make adjustments to my front shocks ?
I jacked-up my front end (tires off the ground), then took the wrench from my toolkit and turned the shocks to the highest setting notch. Perfect.Hi. I have installed a Glacier III plow system with a 66 inch poly blade on my 2012 polaris sportsman 550 touring , my question is do i need to make adjustments to my front shocks ?
What year/model Polaris do you have? (List your quad in your signature, it helps out a lot.)Polarus offers front spring spacer to help off set weight of plow there like 20 bucks have them on mine
I have a 2012 sportsman 550 epsWhat year/model Polaris do you have? (List your quad in your signature, it helps out a lot.)Polarus offers front spring spacer to help off set weight of plow there like 20 bucks have them on mine![]()
