First of all hello, I'm new here. I put a new battery in my mother in law's friend's Polaris Sportsman 450 a couple weeks ago thinking that was the extent of her starting problems. The battery was dead and it now started so I figured it was a go. I took the ATV out this weekend for a test drive and it died after not too much abuse. I was about to hit this mud section for another go around when it just died.
The starter catches for a split second and then spins freely. The ATV won't start even using the pull start. After the tow back to the campsite, I took the flywheel cover off. I found that the starter drive was trashed. It was nice enough to split out some metal chunks that some spring holds in. Those metal chunks took out my coil pulser. I hope nothing else got beat up too bad.
I'm looking for a walkthrough on replacing the coil pulser. Looks like I may need to pull the flywheel to gain full access. Instructions with torque specs and clearances would be much appreciated.
I see mfgsupply has heavy duty starter drives for $50. The local dealer wants $160 for one. Should I go with the overpriced OEM which has already proven to fail or does mfgsupply make a good starter drive?
