The manual says no more then 3 pumps but I can't see new grease. Should I? I was able to see new grease on all the other zerks, as well as the nastyness that came before it, but not this one. I did use the ujoint grease. Am I missing something or doing something wrong. Thanks for the help in advance.
Forget the Polaris sales pitch of different greases, use one for all. Three pumps is enough. More is not always better.
Thanks for your help but should I not see new grease. I am using a grease gun with the smaller hand pump not the full lever, it is a 14oz pump though.
Load em up whenever you get muddy. I always do when im in water just to push out any water in the joints and the yoke on the driveshaft only do like 3 times a year depending on how much you ride. I do almost every 100 miles
