Anyone know the size of the grease zerks on the upper front A- Arms? I want to change out the straight ones for 90 degree pieces. The 6mm assortment I got at the auto parts store have been the only metric sizes I found and they are too small. They look like a tapered thread.
Stave, I know you have a tap and die set, screw the straight fitting in to the die or screw a tap into hole and find the thread size....
When I changed mine I had a assortment from NAPA and that worked.
NAPA 715-1085 is what I used. Looks like a few of the fittings are not in the correct place in my box....... it was the 1/4 PT 90 degree used
6mm =15/64
1/4" = 16/64
I got a selection of metric and SAE grease fittings so I could find the right ones. Appears to be 1/4-28 tapered fitting. At least that is what I got threaded in there. Took the left upper arm off so i could be sure. Got them all changed today.
