I have a question for anyone who serviced ATV's specifically the side where the pull starter (on older models) and/or the starter system in general (all models).
I have a 2006 Polaris 450 and I go through a starter about once a year. I was told by the local dealer that starters should have a life of at least 3 years when all is good with seals, etc. Basically moisture or water gets in the starter itself or condenses somehow and the needle bearings seize up on the output shaft to the point that I get a solenoid click. Alternately it could be constantly turning when running via the flywheel with no engagement (see next paragraph for description of issue).
The person I bought it from says this has been a common problem for them, hence I got it with that problem along with a broken recoil which I rebuilt and starter was replaced. I always seat the pull handle properly before a run or when storing.
I recently had the starter freeze up on me again and it seems moisture got in the starter somehow even though I do not go through mud or water at all, mostly dry trail riding. No dust getting in the case, just water. I can only assume rain is the issue as I do not have a dry storage place. It is frustrating but that issue is for another thread. Upon inspection, most or all the grease was gone after a year. Maybe more grease next time...
What I am asking is should I regularly grease the Bendix shafts (both sides) and also should I grease all the teeth there is (starter, Bendix drive, flywheel) and how often and how much? What grease should I use, waterproof or my main Lucas Xtra Heavy Duty (green kind)? It is safe to use as a dielectric, and works well for me on practically everything. But Polaris makes a special grease for this side as I found by searching grease. Always something special from them lol. Should that be used or does it matter? Service manual seems vague on this issue of lubing the starter side...
