Hi All,
Picked up a 2006 Predator 50 last night in pretty rough shape. I haven't had time to figure out why yet, but it doesn't run, and the plastic is not great.
Things I know I'll need:
Plastic (once it runs)
Muffler (unless this one can be welded)
Kick start return spring
And I'm sure an ever growing list.....
I look forward to your insights in fixing this thing!
Welcome to the board! Do you have a service manual? I have the 04 50/90 predator/sportsman if you need it, just send me a pm w/your email.
Yes, I found one in a link here, thanks for the offer! I'll post more once I get it home, it's sitting at a friend's house right now.
Welcome to the board!:med:
Welcome to the forum!
Ok, so problem discovered: the previous owner tried to install a new piston, and didn't instal the circlip correctly, and it popped out and wedged in between the piston and the wall before being caught in the intake port. Fortunatly, all the metal seems to be there.
Here's my question, with the piston removed, should there still be some resistance when the kick start lever is pushed? This one has more than I'd expect...
The connecting rod seems fine, and does not seem to have excessive play. However, the crank does not seem to roll easily; I'm used to working on clutched \ geared machines, where the crank can be spun by hand with the cylinder off, can you do that with one of these cvt machines?
Also, as I'll be looking for a cylinder, can someone tell me what machines and brands interchange? Thanks all.
