i have a 94 polaris 400l 4x4 on demand first anyone know where to get a manual for this to download free and second the problem this atv is having issues with shifting it seems like its always engages the secondary clutch spins a little on idle in neutral and when trying to shift it just grind and wont shift into gear from neutral to high or to reverse both grind i did get it to start in neutral and go into reverse with no problem and quickly shift to high and no grinding but if I try to start it into neutral and shift into high it grinds and wont shift same for reverse most of the time. belt sqeals thinking I need to change it not really sure. anything will help I can start it in high sometimes it will engage and be good to go but sometimes not any suggestions would be greatly appreciated thank you
