1 - 12 of 12 Posts
I need to replace the grips on my 2015 sportsman xp 1000. Lots of choices out there, whats the best and why?
Check out Oury grips, used them on my old sport quad and now my Sportsman.
Grips are a personal choice - I like Pro Grips, they are larger in diameter which fitm my grip better and they are gel type grips (don't get slippery when wet)
I just installed some pro-taper pillow tops. I won't be able to try them until the spring, but so far I like them better than stock!
Discussion Starter #8
Its all about what YOU like best.
I get that, just trying to get some suggestions of what guys are running so I can look into those... I pulled up grips for my machine and had only about 500 billion to choose from, so just trying to narrow that down a bit and get input from people that have used them!!!
Gee, if you are like me, you'd have less choices to worry about. I only use ones that are heated....
I have Heat Demon heated grips, bigger diameter which def helps longevity in grip strength esp if you use your machine to plow like I do.
1 - 12 of 12 Posts
