I have a 550 EPS,EFI that is backfiring and hard to start and now can't get it started. I changed the spark plug and still backfired and didn't start. I would like to check the battery but can't remove the compartment cover after releasing the latches. I have jerked it every which way without success. Anyone have a suggestion?
Welcome to the board!
If its under the front rack, undo the lock and ride clips and give it a good firm tug up on the headlight side. The fronts have T clips that sit in a slot. You will see them when you get it out.
Welcome by the way.
