1 - 20 of 22 Posts
Just letting everyone know I have a FSM for the Hawkeye. It is for the '07 model, but alot of the pictures show a '06 so I'm sure it will cover about everthing for the 300 Hawkeye/Sportsman.
If anyone has a maintaince/service question post it up and I will get the info back to you here out of the manual.
300 hawkeye.
my granson has a 300 hawkeye and naturaly got it wet.dryed out for about a week now,but still wont fire ?? cant find any fuses and no manual to tell where they are at. would you please help us with this?? thank you.
What does FSM stand for?
I bought a Polaris manual,but it does not show full routing of vacuum hoses for the carb. Purhaps it is not FSM. I would appriciate any photo's one might have[or verbal description] of proper routing.
What would you charge to put the fsm on a disk and send it to me? I found a manual for sale but its around 50 bucks and I need to save money to get my Hawkeye running correctly.
Thanks,
George
I purchased on-line from midwesternmanuals.com , Put on hard drive ,then make copy.Simple.
To get Hawkeye to run good just purchase the Dynojet jetting kit.
I tryed to find the online manuals and had no luck, that address didn't work for me? Is there something missing? I even tryed using www infront and no luck.
Remove carb hawkeye 300
Hi there can you tell me how to remove the carb from a 2006 Hawkeye 300? - I have all the hoses and choke cable off, how do I remove the throttle cable from the carb?
Louis
FUSE SPLICE SAVER
The fuse splice saver is near the battery under the front storage
compartment.
Rear Axle Parts?
My 2006 Hawkeye has a loose LR axle at the transmission. I removed the boot to see what part was broken thinking I'd find a CV joint. What I got instead was a handful of ball bearings and the remnants of the bearing housing.
When I look at the Parts Catalog I don't find any type of u-joint. I guess I could look at the other side but I hate to mess with what isn't broken. Anyone have a description of what parts are included in attaching the rear axle to the transmission?
1 - 20 of 22 Posts
