I texed about a week ago with bad head gasket changed gasket will not start fowling plug did not take cylinder off you think I should remove cylinder to check for water still no water in sump don't think its water pump its a 1997Polaris 400l xplorer?
Have you checked compression? Is the plug fouling with fuel, oil or coolant? Have you checked the counterbalance oil for coolant/water.
I checked the counterbalance sump no water it wets the plug with carb off you think water still in cylinder ports?
