1 - 2 of 2 Posts
I have a 2009 Sportsman 500 HO that I bought used a while ago and the wires going to the headlight in the pod are cut. (Can't believe someone would actually cut the wires?) There is a few inches of wire remaining on the bulb retainer but I can't find where the other end of the wires are? The wires going to the bulb are yellow and a purplish color.
Where do the headlight wires go? Any ideas on how to fix this?
Discussion Starter #2
Well I figured it out! :) The two wires that go to the bulb broke off right where they come out of the wiring harness. Polaris used cheap wire and over time it fatigued and broke off with the constant back and forth motion of the handle bars.
I solder the wires back on and all is good!
1 - 2 of 2 Posts
