Hi,
I had to adjust the handlebars and while taking everything apart, I noticed a broken O-ring around the attachment point of the headlamp to the swivel bracket. Is this something I'm going to need? Both sides of the headlamp had either a broken O-ring, or almost broken. It was a mess getting the whole assembly cover on and off, so if I can just leave these O-rings off, I'm going to. I just use the ATV to work on my farm, so I'm not mudding or any of that hard riding. I do an occasional mountain ride in NC, but that's about it.
Thanks for the input.
W
It's not critical but will keep the headlight from bouncing around. Any plain old vanilla o ring of the right dimensions will do.
Don't have it in front of me, but maybe a thin bead of silcone might help you out if you can't get a O-ring.
Anyone know the size of the O-rings for the light pod and head lights? If I look on ebay they are outrageously expensive. Some 2.95 for 1. I need 24 of them and not going that route. If I knew the size I can search that and pick up 50 for only 8 bucks. Just don't want to order the wrong size and have something that won't work.
Thanks, Ultra
Just found the size. Does anyone know the difference in material of the O-rings and what will last the longest? EPDM, Viton, Silicone?
go to tractor supply or a hardware store that sells nuts an bolts an such..most have a good selection of O rings...if you have an ACE hardware close by they have them...have got a few from them...
Thanks al53. I went to ace the other day and they only sold them in a packet of 1 for. 69 each. I need 24 so not going take route. I ended up ordering some 206 EPDM ones on eBay last night. 30 for $7. That should take care of all of mine. Thanks for the response.
Sent from my SCH-I545 using Tapatalk
glad you got them..did not know you needed that many..loll..I dont know how your set is..but would rubber washers work
Think elastic bands, not seals or washers!!
Mark
