Could someone please help me with a headlight problem? Both the low and high beam headlights do not come on when the switch is selected on the handle-bar. I have a 1998 sportsman 500, and recently had this problem. I don't know if there is a schematic for the wiring. I have not seen anything on the polaris homepage. I think my problem is a fuse, but I do not know where this may be located.
First off, Welcome to the board!
What about the rest of the lights, power to 4x4, etc. Fuse should be in back not far from the solenoid, Check under seat, should be 20amp.
you might have to take the hood off. on mine the circuit breaker was bad and is under the hood tucked in with all the other wiring. they are wrapped in a waterproof(yea right) black plastic bag.
