1 - 2 of 2 Posts
I own a 2008 SP 500 EFI. The high beam headlight is out. I removed the headlight cover and pulled the wire plug off the lightbulb. With the key ON and the headlight switch on HIGH BEAM there is no power to the bulb. The small high-beam blue light on the switch is illuminated. The low beams both work. Any information on trouble shooting the switch or wiring???
Thanks!
make sure you have juice going to and from the switch on the handlebar. you might have a dirty connection in there or something just got jarred loose
1 - 2 of 2 Posts
