1 - 20 of 63 Posts
Does anyone know if Polaris is making heavy duty front springs for the 570? or if the 500 springs will work? part number?
Not looking to raise the front end just limit the sag with the plow.
Also I don't want to replace the rears.
Thanks in advance
Yes. The 500's work on the 570. Just put them on mine last week
do you happen to have the part number? did the raise the front end at all?
thanks
I dont have a part# on hand. Just go look up pure Polaris parts catalog, that's where I got the # from. I bought mine on eBay for $80, free shipping. And yes it did raise the front, but not much. Took the rake out of the front with my winch on.
coming up with part number 2876153 does anyone know if these will work?
Discussion Starter · #7 ·
thank you
No problem. And no need to use a spring compressor to change the springs out FYI..
Discussion Starter · #9 ·
cool that was my next question.
it doesn't make the front end higher than the rear does it?
Nope. Makes the quad pretty level and as an added bonus, take the caster out if the front wheels. If you noticed the front wheels lean in when the front is squatted down.
Discussion Starter · #11 ·
yes I did notice that. thanks for all the info.
so no problem compressing the spring? the stock ones seem prettly loose when jacked up so I did wonder.
Yeah the stockers are pretty weak. Even the HD's aren't hard to compress. Just use the weight of the machine to your advantage
Discussion Starter · #13 ·
thanks for the info.. did you do anything to the rear ?
I cranked my rears up 2 notches (middle setting) on the preload. I ride 2 up sometimes and it was a touch too soft. I'm 200lbs and my girlfriend is 125. The middle setting worked out great.
Discussion Starter · #15 ·
awesome thanks. that is what I was hoping to do.
Your welcome. Good luck
Discussion Starter · #17 ·
done! thanks Kme743 piece of cake. Like you said no spring compressor necessary.
much better to do all four, i did the polaris front hd's and it made the back begin to sag so i took out the hd's and put in 4 highlifter HD's, hole new machine, much better ride
1 - 20 of 63 Posts
