Today I bought a 99 Sportsman 500 HO that needs some TLC. My biggest concern is the fact that what I thought was a vent that hangs from the bottom of the carb. bowl runs a pretty steady flow of gas whether the motor is running or not. Any suggestions? Thanks, Jeff
First off welcome to the board!
Hey Jeff, welcome to the board!
Is the thing you thought was a vent really the bowl drain? Does it look like it's got threads on it? If so just tighten it up (this may require a pair of pliers)and the leaky-leak should go away. HTH.
-J
Oh, and I forgot to ask - what part of Central IL?? I'm in Greenville, just north of I-70 a bit.
-J
Discussion Starter · #7 ·
It's actually a hose that hangs from the bottom of the bowl. It has something in line that resembles a filter of some sort!
