New here. Been a member for a couple of weeks now but never had the time to jump on and say "hi". I have (will be purchasing from my father-in-law) a 2012 Polaris Sportsman 500 HO. His grandson has ridden it around and something has happened to it. There is a flashing wrench icon on the speedo display. We can get it started but it won't idle, nor does it have any top-end what-so-ever. I had first replaced the fuel pump thinking that it had failed. I determined this because I had taken it apart and had noticed that the diaphragm and the valves appeared for better wear. I have taken the carburetor completely apart and cleaned every orifice and jet, but with no effect.
I am wondering what else to check for, I am stumped on this one.
Thanks.
Robert.
Welcome to the board!
2016 Polaris Sportsman 1000 XP Hunter Edition
Welcome!!!!!!!!!!!!!!!!!!!!!
Welcome we will be down to your state to ride in late June. The flashing wrench may just be a service due indicator that can be reset.
Thanks.
Robert.
Hi Robert, I'm also new to the forum but I would check and see what codes it is throwing before you throw parts at it. That flashing wrench is telling you there is a problem. Yes sometimes it is just a maintainance reminder but in your case where it is not running right, there is a code that will help you narrow it down.
