I just bought a 2005 polaris trailblazer 250. It runs good and everything but I notice a problem when you first start the atv it's really accelerated and stays that way. The acceleration it will not come down? And because of that it will not change to reverse or to neutral.? And if you change it that way you will hear a nock on the transmission.? I need help ????
Check the throttle cable for any kinks or binding.
I have checked the throttle cable but I don't see nothing wrong with it. At first I checked the throttle cable Where the carburetor is and the cap that holds the throttle Cable and it was a little Loose i tight it .i thought that was that but no.
Have you tried adjusting the idle screw? Carb slide stuck partially open? If it just started happening all of a sudden maybe you have a cracked carb boot or leaking crank seal. That will cause all sorts of running issues like that.
