I'll start by saying hi, names Aaron and i just signed up. I didn't search for this topic yet, just throwing this out there to see if anyone knows anything about it.
I bought an 07 predator and had it for a week and it started acting up. Whenever it got a little wet it would sputer and cut out... untill it dried up.... So i thought. I'm now on my 4th battery because my bike will run great on a brand new battey for about 7-9 hours then die. When i hook up a meter it tells me the voltage is good (about 12.8 or so). After every battery stopped working i had them tested... the first 3 batteries all had good voltage but no cranking amps. Has anyone came across this problem... Your bike over killing the cranking amps?. I've had my starter checked to see if it was drawing to much current when starting but it turned out okay. Any ideas would help, thanks.
Voltage regulator rectifier maybe.Check it and see.Hopefully its not the stator.Let us know the results.
Welcome aboard!
