08 sportsman 800 HO 4x4is severely sagging and it doesn't seem to want to hold my suspension up on my rear right hand side it's druping my whole quad South I'm guessing any heads up or any info detailed on what part and what being the issue will be gratefully appreciated hit me back thank you appreciate your time
I would get that but it's only sagging on the right side rear and some right side front of the quad hardly no sagging whatsoever on left side of quad thanks again once again for your time appreciate any other info but will check on this
Jack it up to get all four wheels off the ground and check bushings, shocks, wheel bearings, tire pressure, frame cracks, etc.
