Hey guys,I can be riding my bike an it runs great then sometimes I can let off the gas an it will just cut off...it sounds lime the fuel filter. I was going to take it off an clean it but not sure what to take off an clean because it a lot between the gas line an the carb so Im not sure what to try an clean can someone help me please an thank you
I am no expert by any means but I had a similiar issue with my 2012 400 HO and it was the throttle cable. When I let off the throttle it basically cut all fuel to the carb and shut of the quad off completely. Worth a look IMO...
So what did you do with the throttle cable...... Turn up the idle speed, replace the cable or adjust the free play???
