I'm trying to clutch my 2007 Sportsman 800. I've bought a Dalton Primary spring which is good for tires up to 27". I've also have a EPI Sport Utility Clutch kit for 27" tires. The EPI kit comes with 1Primary spring, some weights and a helix and spring for the secondary. I was planning to use the Dalton Primary spring instead of the EPI one (due to it looks better and heavier than the EPI one) would any one reccomend this? I thought you want a heavier spring on the primary for engagement? I'll be riding mostly trail (60%) and some mud (40%) and will be running 27" Outlaws 1 skinny wide combo? Can someone shed some light on this situation? On the Dalton website it states just use the Dalton Primary spring cause the polaris clutches are good to tires up to 27". Is it a good idea to mix and match the two? The springs look the same, but the Dalton seems a bit heavier? Thank you
