1 - 13 of 13 Posts
Under the seat I can see a foam block with a big hole like something is missing and on further down inside I can see another hole like something connects to it, hard for me to discribe so here's a picture. Bike seems to run fine.
Ya looks like your miss your intake tubing for your clutch housing. The small tubing just trace time back and see where its going/coming from it might be the carburetor drain?
The tube does come from the bottom of the carb but is it suppost to hang there like that?
Yup carb tube just hangs
its for overflow. nbd, but your missing the tubes Is A Big Deal. You really need both for proper operation, filtering of air and cooling of belt system. :cowboy:
No filter that I know of in the clutch duct work, but it will let a bunch of water onto your clutches, which will leave you stranded in the middle of a creek crossing while you sit there smoking your belt, wondering why you aren't moving.
Ya just tuck it between the engine and the transmission and you will be fine. Ya you need that tubing for the clutch definitely!
No filter that I know of in the clutch duct work, .
uh right, filtered air for engine, cooling of belt system...
When you put that vent tube in make sure you seal it up. I put a little silicone on it slid it it and put a zip tie around the rubber to hold it in place
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Discussion Starter #12
I recieved my used vent tube I bought through ebay and all is well! Thanks again for helping a new Polaris guy out!
1 - 13 of 13 Posts
