1 - 12 of 12 Posts
hi guys im new to the sit im fixing a polaris for a guy he got new ameger plates i check the gap for the mag, i check the reading on the wires going to the coils are good im after doing everything i could do with it put the hilliard clutch wont lock the hubs in on either side what could be the trouble .
you have it jacked up so rear wheels off the ground....rear wheels have to slip some for fronts to lock in....
on my machine, it all goes thru the speedo, mine all appeared to be working properly, but still no AWD, I bypassed the speedo by grounding it before the speedo, now everything works fine.
Discussion Starter · #8 ·
it was 25 ohms and 12 v. The awd switch is working it lights up. when i push awd the amger plate sticks when i put it in reverse it dont stick till i puch the over ride button like it should im puzziled
1 - 12 of 12 Posts
