I have an '05 Trail Boss 330 and I have lost my key. I recently moved and don't know what happen to the key. I am blaming it on the wife! We are planning on making a trip down to the sand dunes in Wanoka next week. I know I can replace the ignition switch but a guy at work said I should just be able to bypass the ignition switch and put in a toggle switch. So basically I would be hotwiring it. Does anybody know how to do this on a Trailboss? I am planning on tearing the new house apart this weekend looking for the key, but if I don't find it I am trying to see what my options are to get me running for the trip.
You can just pull the center of the ignition and tumblers out and start it with a screw driver until you get a new ignition. Only problem with this is if you find your key later on you will have a hell of a time getting the tumblers back in in the right orientation.
Good luck
Discussion Starter · #4 ·
Thanks for the reply Monte. I ended up finding my spare key. I have never used it and at first it wouldn't turn the ignition, but I knew it was the right key. So I ended up just filing down parts of the key little by little and kept trying it and finally got it to work. So I am all set. Can't wait to go ride this weekend!
