no but it was cleaned very well and fresh gaswas the carb rebuilt with fresh jets, new needle, new floats, new needle valve that kind of stuff?
well wen i hit the gas it wont move but it bogs down but does int dieCheck the belt!
its all solid state ignition but please explain moreIgnition timing from sprockets
the srcew is all the way outIt has a governor screw on the thumb throttle if its screwed in to far it won't move. Try backing off that screw.
