just put new carb on my quad and cant get it to run.been jumping solenoid runs as long as screwdriver is contacting both terminals.as soon as i remove quad shuts off.also when i put my hand over back of carb get lot of suction but gas pours out back of air box tube.can anyone help me.
I could, but I'm not there and the quad is not here - it sounds like you have multiple problems.
First, disconnect the black wire at the CDI box to eliminate ignition as a potential problem - getting gas out of the carb if you hold your hand over the intake is normal - if it can't draw air it will draw fuel. Since it starts jumping the solenoid with a screwdriver, I suggest you fix the starter circuit first to get the solenoid to close using the starter button.
Related Threads
876.5K posts
113.4K members
Since 2008
