1 - 10 of 10 Posts
Hi guys, i had charging issues and turned out to be a bad stator. The service manual states to drain the oil before removing the stator so i did. I proceeded to remove the stator cover and found oil in it. Is this normal? i cannot really find any info. I'm wondering if that's what blew my stator in the first place. Why drain the oil then?? Your help and guidance would be really appreciated.
I am not to familar with the 2010 machines..but I cant understand why you need to drain oil....and oil in there is not normal I believe....you pulled the flywheel right....did you see any oil seeping from the crank seal....was it wet...I just looked at the parts fiche....it does have a oil seal in that area...you may have a leaky seal if you have oil in the magneto area.....
Discussion Starter · #4 ·
i didn't pull the flywheel at all. just the stator cover which the stator is attached to it. Can you provide the part number for that seal?
wait till some one chimes in also..like I said not to sure on the 2010 models and way its set up in the magneto area.....
you learn something new on other machines every day....I would of never thought the stator was in oil...I guess I am use to the older models and figured no oil in stator area...thanks for clearing that up...sorry to OP but like I said was not sure how magneto area was set up..
Discussion Starter · #10 ·
Thank-you all for your help. I was also able to confirm it via the salvage yard out of all places. I called 2 Polaris dealers and they either really didn't know or did not want to divulge the information. I changed it and its all good now :)
1 - 10 of 10 Posts
